Even with my refrigerator control down on one, my refrigerator still goes through "cycles" where it gets cold enough to freeze my food. Could it need a new thermostat? I just cleaned and vacuumed the coils and everything. Thanks:confused:
I would first measure the freezer back wall temperature. If higher than 10 -15 degrees, pull the back freezer panel and check the frost pattern.
