You have been a member since:: 5/24/2012(UTC) Posts: 1
All of a sudden, the food is freezing in the fresh food compartment. Turned down thormostat, still freezing. Friend suggested turning down the temp in the freezer compartment, did not help. Any suggestions?
Groups: APP Team
Hi. Based on you description the problem is with air damper control, witch is not sold separately. You will have to get The control box assembly Part number: 5304482075
Freezer air going into refrigerator through vent that is not closing when set temperature is reached. Replace thermistors in the refrigerator.
