jonamying
#1 Posted : 17 years ago
jonamying
My refrigerator is freezing. It is so cold in there that even the mayo is frozen. Turning the temperature dial does not help. Amy:eek:
#2 Posted : 17 years ago
Measure your freezer temperature and post.
jonamying
#3 Posted : 17 years ago
jonamying
It is 8 degrees F.
#4 Posted : 17 years ago
Click on your model # above and locate the damper assembly on the fridg. left wall part # 426 Unplug connector to it and jam door 1/2 way open. This will temporarily fix your problem. Basically, if your damper door is jammed and will not move easily, you will need a new one. When plugged in and will always motor back to full open, you have other problems
If you can troubleshoot with a meter, go to web site www.*************.com/forum1/3075.html There you can get info for measuring you thermistor resistance for the fresh food section. Either you have a bad damper assembly or a bad motherboard in the back, or a bad fresh food thermistor. The service sheet should help if you find one. GE, in most cases has not supplied one. This service sheet is generic, and will not have wire color codes, but it is better than nothing!
Whirlpool refrigerator freezes everything! (Refrigerator & Freezer Repair)
by Soccergkphillip 11 years ago
Americana Refrigerator Freezes Everything (Refrigerator & Freezer Repair)
by floyd3609 13 years ago
refrigerator freezes, freezer defrosts, conatantly runs (Refrigerator & Freezer Repair)
by billdherup 13 years ago
refrigerator freezes in the fridge side (Refrigerator & Freezer Repair)
by ZURTA 13 years ago
refrigerator freezes everything (Refrigerator & Freezer Repair)
by Charles Scott 14 years ago
Refrigerator Freezes (Refrigerator & Freezer Repair)
by candelida 14 years ago
Fridgidaire Refrigerator Freezes (Refrigerator & Freezer Repair)
by LBsr 14 years ago
Garage refrigerator freezes food in low ambient temperature (Refrigerator & Freezer Repair)
by Dave Kuch 14 years ago
Refrigerator freezes up every 5,6 days (Refrigerator & Freezer Repair)
by nguyenhung77478 14 years ago
Refrigerator freezes food & drinks (Refrigerator & Freezer Repair)
by Frank S. 15 years ago
Refrigerator Freezes Food (Refrigerator & Freezer Repair)
by quadkellys 16 years ago
freezer and refrigerator freezes too much or nothing (Refrigerator & Freezer Repair)
by borgirek 16 years ago
Refrigerator freezes everything (Refrigerator & Freezer Repair)
by Susan 17 years ago
refrigerator freezes fresh food (Refrigerator & Freezer Repair)
by rondawn 17 years ago
