My refrigerator is freezing everything!!! I just replaced the thermometer ($45) because it would get warm. Now I can't keep anything from freezing in it. The thermometer "stick"/gauge of the replacement part was not identical to the one I pulled out and is 2-3 inches shorter so I don't have as much exposed. Could it be that the new thermometer thinks the fridge is warm bc the plastic tubing is insulating the gauge? The manufacture date is 08-01 Please help! Soccergkphillip attached the following image(s):
What is the freezer temperature?
Originally Posted by: richappy  What is the freezer temperature? I'm not sure...the only control is in the lower refrigerator section. I have barley turned it on and it freezes everything. I let it thaw and turn the dial completely and, of course, freezes everything.
