Frank S.
#1 Posted : 15 years ago
Frank S.
four days ago i noticed that my sodas,milk,water had some frozen peaces in it,i left it alone two days later all my food,drinks were frozen.i tryed turning the temp to a warmer setting,still nothing everthing is frozen.what can it be? the thermostate?:confused:
#2 Posted : 15 years ago
Frank,
Most likely the problem is a bad damper control (#115 on the diagram) which should regulate cold air flow into the refrigerator. Frigidaire has redesigned it and now it comes as a part of the control panel. You have to install all new parts.
- The damper control kit Part number: AP3140255
