dean6883
#1 Posted : Wednesday, October 13, 2010 10:14:57 AM(UTC)
dean6883
My dryer overheats and stops. I replaced the temp sensor, heatiing coil and one time fuse. It did two loads and stopped. I had a repair man install another fuse. It ran 2 loads and quit. He came back and cleaned debris out of a black tube in the bottom and said the vent was plugged. He put another fuse in it. One load and it stopped again. Any ideas on what is wrong?????? My wife is ready to shoot me and the repair guy.
#2 Posted : Wednesday, October 13, 2010 3:08:28 PM(UTC)
Originally Posted by: dean6883 Go to Quoted Post
...He...said the vent was plugged...
Which vent - inside or outside the dryer? Did he unplugged it?
You may want to check the vent outlet and, if the vent line is more than 2' long, call a professional vent cleaning company.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL REX3514PQ0 29"electric Dryer | AppliancePartsPros.com
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 4/19/2020 3:58:45 PM(UTC)
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
roper dryer (Dryer Repair)
by smoke-71 3/3/2015 3:56:21 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
