Boatechian
#1 Posted : Tuesday, October 5, 2010 1:14:24 PM(UTC)
Boatechian
Greetings,
Drum will not turn, manually turning will start, otherwise motor just hums. Is there a start capitor or thermal disc, etc., that starts motor or is motor just defective?
#2 Posted : Tuesday, October 5, 2010 1:35:19 PM(UTC)
Replacement parts for WHIRLPOOL WED5800SG0 29"electric Dryer | AppliancePartsPros.com
[COLOR="Blue"]Is there a start capitor or thermal disc, etc., that starts motor[/COLOR]
No, the motor uses a start winding to start it. This is then switched out of circuit by a centrifugal switch built into the motor assembly once the motor gets close to operating speed.
[COLOR="Blue"]or is motor just defective[/COLOR]
Yes odds are high that the motor is toast.
One thing you could check is that there is not a bad or loose connection to the start/run switch on the motor.
Boatechian
#3 Posted : Tuesday, October 5, 2010 3:06:54 PM(UTC)
Boatechian
Denman....Thanks for the reply and suggestions, much appreciated.
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 6/8/2022 5:45:29 AM(UTC)
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 9/26/2018 9:11:22 AM(UTC)
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 10/8/2017 9:57:09 AM(UTC)
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 3/21/2015 9:53:19 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
whirlpool electric dryer (Dryer Repair)
by ajlgap19 6/6/2014 9:55:32 AM(UTC)
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 1/23/2014 7:03:27 PM(UTC)
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 1/16/2014 9:02:04 AM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
by eisehunter 5/28/2013 1:44:53 PM(UTC)
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 2/6/2013 12:59:47 PM(UTC)
Whirlpool Electric Dryer (Dryer Repair)
by mayork 11/14/2012 10:21:04 AM(UTC)
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 9/10/2012 2:08:11 PM(UTC)
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 8/20/2012 12:48:36 PM(UTC)
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 8/18/2012 1:10:17 PM(UTC)
