Here are youur parts. Note that the wiring diagram does not seem to match the unit. It is for a gas unit not an electric.
Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.comHere are the parts for a PYE4557. The included wiring diagram should be a close match to yours.
Replacement parts for MAYTAG PYE4557AYW Dryer - Ele | AppliancePartsPros.comTry flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. The motor use half the line (L1 to Neutral)
Check power to the unit.
Next would be the thermal fuse (Item 5 in Section 5). It should be 0 ohms.
You will notice it comes with a hi-limit thermostat. The reason for this is that the hi-limit should have opened before the fuse and regulated the temperature, so they assume it is also blown (contacts welded together).
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
