cal680
#1 Posted : Monday, July 21, 2008 2:45:13 PM(UTC)
cal680
Washer will not turn on. Water will not enter tub. Checked lid switch - is OK. Suspect Water Level Switch. Tested switch and there is no continuity between any of the terminals - exept when I blow into the tube then terminal 1 and 3 show continuity. Can you advise if this is the correct function? A service man told me that the switch was OK but, doesn't the switch control the electrical load to the timer and let the timer run AFTER water is in the tub. The only cycle the washer will run is the spin cycle so I assume the lid switch is OK (which was proven by the meter) and the motor is fine. If I am testing the switch wrong - can you please advise the correct way.
Thank you
#2 Posted : Tuesday, July 22, 2008 1:02:55 PM(UTC)
There is suppose to be continuity across the terminals "V" & "P" while the washer is empty. You can easy find out if the water level switch is bad by bypassing the "V" & "T" wires. If the washer will work then replace the water level switch.
- The part number for the water level switch is AP2907096
Here are the break down diagrams for the Kitchen Aid washer Model KAWE560WWH3
LIsa60
#3 Posted : Monday, May 19, 2014 5:44:58 AM(UTC)
LIsa60
My mistake Gene, its a GE
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
by bigdanallan 1/20/2011 7:42:20 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
how do you test water level switch (Washer Repair)
by ldutton 10/11/2009 7:04:15 PM(UTC)
