bostonbill
#1 Posted : Friday, September 10, 2010 3:54:29 PM(UTC)
bostonbill
The 1 amp fuse for the washer keeps blowing. I spoke to a tech. He thinks he remembers some type of problem with the lid switch assembly on that model. I did a continuity check. The switch seems fine. Any thoughts would be greatly appreciated. (wifes getting ornery) tx. Bill
sidfink43
#2 Posted : Sunday, September 12, 2010 6:29:35 AM(UTC)
sidfink43
Fuses blow when too many amps flow. This is hard to pinpoint exactly, but I think replacing the lid switch assembly is the most likely solution.
The part is somewhat costly, so if you buy from this site (no we are not associated with the parts operations of APP) and it does not fix things you can return it. See the returns policy.
bostonbill
#3 Posted : Wednesday, September 15, 2010 2:27:02 PM(UTC)
bostonbill
Thanks Sid. I'll give it try and let you know.
Kenmore Stackable Washer/Dryer Lid Switch (Washer Repair)
by C@TCH 3/6/2017 3:27:14 PM(UTC)
GE (frigidaire) Stackable Washer/Dryer Tub Seal Leak! Help Pls! (Washer Repair)
by cdnhawk02 1/17/2014 3:19:11 PM(UTC)
stackable washer/dryer electric (Dryer Repair)
by Blueant 10/6/2013 2:15:59 PM(UTC)
Stackable washer/dryer- Washer won't run unless dryer is running (Washer Repair)
by abracadabra13 9/2/2013 9:55:12 AM(UTC)
Kenmore stackable washer/dryer won't drain or spin (Washer Repair)
by penelope therese 3/20/2013 6:26:11 AM(UTC)
How to disassemble Maytag Neptune stackable washer/dryer (Washer Repair)
by dpilot83 2/24/2013 6:58:09 PM(UTC)
Maytag Stackable Washer/Dryer Going Haywire (Dryer Repair)
by evilnaz 6/8/2011 3:41:48 PM(UTC)
kenmore stackable washer/dryer (Washer Repair)
by karns7 6/7/2011 8:01:26 AM(UTC)
Kenmore stackable washer/dryer (Washer Repair)
by jasonhart1 4/17/2011 9:39:11 AM(UTC)
Need a dial for stackable washer/dryer (Washer Repair)
by ksquire 10/7/2010 3:59:55 PM(UTC)
Whirlpool stackable washer/dryer - washer advances cycles but takes a long time (Washer Repair)
by LynThereDoneThat 8/23/2010 8:29:39 AM(UTC)
GE stackable washer/dryer (Washer Repair)
by realistic 3/31/2010 10:06:02 AM(UTC)
Kenmore Stackable Washer/Dryer not drying clothes (Dryer Repair)
by tamisjoy 12/17/2009 10:06:04 AM(UTC)
maytag stackable washer/dryer (Washer Repair)
by drtstev 9/15/2009 8:17:29 AM(UTC)
Stackable Washer/Dryer (Dishwasher Repair)
by tkh19 4/20/2009 11:12:40 AM(UTC)
