AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool stackable washer/dryer - washer advances cycles but takes a long time
I have a Whirlpool Thin Twin stackable washer and dryer that is from at least 1992 (maybe earlier), Model LT7000XVW0. The wash cycle normally takes 40 mi, but has been taking much longer 90+ mins (slow, but does go through all of the cycles--lately, we have resorted to manually advancing the dial every 5 or so min to move through the cycles).
From the research I've done, I'm guessing the timer or timer motor or both need replacing. Is there any way to differentiate which one(s) need(s) to be replaced (I'm trying only buy what is needed)? (By brother-in-law will be replacing the part/parts.)
Also, are we further damaging the washer by manually advancing it?
I would greatly appreciate your expertise.
It may be the timer motor but it is not shown as a separate part, so check with the APP parts folks. Here is the timer. Part number: AP2911971
If you can order the timer motor separate try replacing it, otherwise you will need to replace the entire timer unit.
Originally Posted by: sidfink43  If you can order the timer motor separate try replacing it, otherwise you will need to replace the entire timer unit. THANK YOU!!!
Washer Repair
