LynThereDoneThat
#1 Posted : Monday, August 23, 2010 8:29:39 AM(UTC)
LynThereDoneThat
I have a Whirlpool Thin Twin stackable washer and dryer that is from at least 1992 (maybe earlier), Model LT7000XVW0. The wash cycle normally takes 40 mi, but has been taking much longer 90+ mins (slow, but does go through all of the cycles--lately, we have resorted to manually advancing the dial every 5 or so min to move through the cycles).
From the research I've done, I'm guessing the timer or timer motor or both need replacing. Is there any way to differentiate which one(s) need(s) to be replaced (I'm trying only buy what is needed)? (By brother-in-law will be replacing the part/parts.)
Also, are we further damaging the washer by manually advancing it?
I would greatly appreciate your expertise.
sidfink43
#2 Posted : Tuesday, August 24, 2010 5:35:28 PM(UTC)
sidfink43
It may be the timer motor but it is not shown as a separate part, so check with the APP parts folks. Here is the timer.
Part number: AP2911971
LynThereDoneThat
#3 Posted : Tuesday, August 24, 2010 5:46:10 PM(UTC)
LynThereDoneThat
Here is the timer motor part for my model:
Part Details - WHIRLPOOL Motor - tmr, part number: AP3134952
I should have the timer motor replaced rather than the timer?
Thank you!
sidfink43
#4 Posted : Tuesday, August 24, 2010 6:02:46 PM(UTC)
sidfink43
If you can order the timer motor separate try replacing it, otherwise you will need to replace the entire timer unit.
LynThereDoneThat
#5 Posted : Tuesday, August 24, 2010 6:38:34 PM(UTC)
LynThereDoneThat
THANK YOU!!!
