Damn plastic switch crumbled into pieces, don't want to pay $70 for new one. Is there a way to bypass the switch to get it running again.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
In short yes, but that is a big safety issue, we don't recommend. Check with some local repair services to see if anyone has a used one if price is the issue. Also find your part number and search ******** for good used switches. Remember though at APP you receive quality OEM parts that will last and have a 365 warranty.
I'm not concerned about safety as it's only myself using it. Where would one search for used parts.
By entering your part number as a search you will find the part likely on "E.B.A.Y" I guess they omit it with ********* if you spell it out correctly as I did in the previous reply
