drtstev
#1 Posted : Tuesday, September 15, 2009 11:17:29 AM(UTC)
drtstev
Washer won't fill with water. Everything else works fine. Already replaced mixing valve. Will work if I fill from outside source.
Frank / APP Team
#2 Posted : Tuesday, September 15, 2009 12:02:19 PM(UTC)
Frank / APP Team
Can you post the model #? Some of the earlier models with electronic controls (SE1000) had 24 volt water valves. If you put in a 120v valve that would sure stop it from filling.
drtstev
#3 Posted : Tuesday, September 15, 2009 2:12:11 PM(UTC)
drtstev
I can't find the model#. Looked all over the darn thing.
Frank / APP Team
#4 Posted : Tuesday, September 15, 2009 2:27:15 PM(UTC)
Frank / APP Team
Is it got a touch pad or is it manual controls?
Did you open the dryer door and look there?
drtstev
#5 Posted : Tuesday, September 15, 2009 2:32:44 PM(UTC)
drtstev
Looked in dryer door, nothing. Controls are manual. Turn dial that you pull to turn on.
Frank / APP Team
#6 Posted : Tuesday, September 15, 2009 2:40:43 PM(UTC)
Frank / APP Team
About the best I can do without a model, is to remove the front panel, and with the help of a volt meter, start back tracking from the water valve. There are a number of parts involved. Some stacks had a fuse in them.
Maytag Stackable Washer/Dryer Going Haywire (Dryer Repair)
by evilnaz 6/8/2011 6:41:48 PM(UTC)
