Door switch good. Start switch good. Have power to termimal on back of unit. The dryer vent is clean No way of checking air flow switch need wiring diaghram
What all parts are needed to heat the electric dryer?
Originally Posted by: gcobbe ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Door switch good. Start switch good. Have power to termimal on back of unit. The dryer vent is clean No way of checking air flow switch need wiring diaghram You may want to check the thermal fuse (#59 on the diagram) for continuity. - The thermal fuse Part number: AP3133489
Originally Posted by: MBKENMORE ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What all parts are needed to heat the electric dryer? What is the complete model number of the dryer? What exactly is wrong with the dryer? Gene.
Thanks for the info George
