jusjuli
#1 Posted : Thursday, September 9, 2010 9:59:09 AM(UTC)
jusjuli
Door switch checks ok, thermal fuse checks ok, starter switch signals the timer but absolutely no motor movement in any mode
Joe / APP Team
#2 Posted : Thursday, September 9, 2010 10:48:46 AM(UTC)
Joe / APP Team
Jusjuli,
I take for granted you have a meter to run more tests ?
Do you have the wiring diagram for the unit ?
You want to set the timer in a timed dry setting and check the terminals for a closed circuit
Check Blue to Black terminals on the timer(wires off).
Check Tan to White terminals on the timer(wires off).
*** Be CAREFUL, this is a live voltage test ***
If those circuits check OK, and you're sure the thermal fuse is a closed circuit, you'll need to check for 120 Volts AC on the blue wire on terminal #4 on the motor.
If you have the voltage, you'd have a bad motor.
Or a broken White wire from the motor to the timer.
If you have no voltage, You've got a broken blue wire from the start switch to the motor.
Hope this helps,
Electric dryer will not start (Dryer Repair)
by lsandks 4/7/2014 1:15:53 PM(UTC)
electric dryer will not start, hums (Dryer Repair)
by embalke 7/11/2011 4:50:14 AM(UTC)
by Equitable P&F 11/2/2010 10:25:30 AM(UTC)
G.E. Electric Dryer will not start (Dryer Repair)
by jdnark 9/26/2010 8:49:50 AM(UTC)
by gcobbe 9/8/2010 8:53:16 AM(UTC)
my kitchenaid electric dryer will not start (Dryer Repair)
by klr.pbird 5/15/2010 2:41:31 PM(UTC)
maytag electric dryer will not start (Dryer Repair)
by jamesdonald 11/18/2009 6:36:19 AM(UTC)
GE electric dryer will not start (Dryer Repair)
by qzymfl 7/19/2009 2:10:26 PM(UTC)
by livergrrl 7/3/2009 1:59:36 PM(UTC)
Whirlpool electric dryer will not start (Dryer Repair)
by graham 2/27/2009 5:28:16 AM(UTC)
by kheinrich 8/21/2008 7:04:59 AM(UTC)
