slick154
#1 Posted : Friday, September 3, 2010 8:59:30 AM(UTC)
slick154
I have replaced the heating element and the thermostat, dryer still will not heat. Vent is clean, will not throw hot air, timer works ok. Not sure where to look next. Any help would be greatly appreciated. This is a electric dryer.
Joe / APP Team
#2 Posted : Friday, September 3, 2010 11:55:38 AM(UTC)
Joe / APP Team
Slick,
Did you check the breakers, make sure both breakers are reset ?
Are you sure you have at least 220 Volts at the outlet ?
Same voltage at the terminal block(where the power cord attaches to the machine) ?
Do you have the wiring diagram ?
I don't have one but could probably use or get a generic diagram if necessary.
the diagram is usually located in the control panel, or taped to the inside of the top, when you raise it.
Good Luck,
:cool: :cool: :cool:
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
