Don Vogler
#1 Posted : Wednesday, August 4, 2010 5:31:09 PM(UTC)
Don Vogler
When you first turn dryer on it makes heat. Within several minutes there is no heat and won't make heat. It is a gas dryer. Everything else works as it should.
ThatGuy
#2 Posted : Thursday, August 5, 2010 4:04:18 AM(UTC)
ThatGuy
Groups: Expert
United States
It sounds like you have a bad gas valve coil. I always replace them as a set. Part number: AP3094251
What happens is as long as they are cold, the coil's winding makes contact. After it lites the first time the coil warms up and becomes an "open" circuit.
No heat in dryer (Dryer Repair)
by davehriver 11/23/2011 11:01:51 AM(UTC)
by jgg35019 11/1/2011 5:28:41 PM(UTC)
NO HEAT in Dryer (Dryer Repair)
by McCarty 8/1/2011 3:08:26 PM(UTC)
no heat in dryer (Dryer Repair)
by trillo 2/9/2011 1:46:38 PM(UTC)
by lucky915 1/11/2011 12:53:24 PM(UTC)
by bill52387 1/26/2010 4:58:09 AM(UTC)
by staschu 1/16/2010 3:31:45 AM(UTC)
Whirlpool Dryer Has no Heat in Dryer (Dryer Repair)
by jsanabia 6/8/2009 2:35:54 PM(UTC)
