hi need help i tested thermal fuse ,thermistor seem to be ok i did find a burned spot on the even heat control could this be the problem?
Hello, The even heat control could be the problem, if you have a volt meter we can test a few things thus verifying the fact. Appliance Repair Technician:
Originally Posted by: Repair Technician  Hello, The even heat control could be the problem, if you have a volt meter we can test a few things thus verifying the fact. Appliance Repair Technician: yes i have volt meter what do I do next ?
Originally Posted by: trillo  yes i have volt meter what do I do next ? how do i test the heat control board
