lucky915
#1 Posted : Tuesday, January 11, 2011 12:53:24 PM(UTC)
lucky915
unsure how old it was a free item
the dryer is just not hot only cool air
how do you know if it is element or thermostat?
#2 Posted : Wednesday, January 12, 2011 12:32:13 AM(UTC)
Here is the parts breakdown.
Replacement parts for WHIRLPOOL LER4634EQ0 | AppliancePartsPros.com
Here is the wiring diagram, see attachment.
First you have to find out if the powers is OK.
The motor etc uses 120 volts while the coil requires the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Once you know that the power is good you can unplug the unit and check the parts with meter.
If the thermal cut-off is blown then are are other things that have to be checked before you replace it.
File Attachment(s):
LER4634.pdf (126kb) downloaded 6 time(s).
No heat in dryer (Dryer Repair)
by davehriver 11/23/2011 11:01:51 AM(UTC)
by jgg35019 11/1/2011 5:28:41 PM(UTC)
NO HEAT in Dryer (Dryer Repair)
by McCarty 8/1/2011 3:08:26 PM(UTC)
no heat in dryer (Dryer Repair)
by trillo 2/9/2011 1:46:38 PM(UTC)
No Heat in Dryer (Dryer Repair)
by Don Vogler 8/4/2010 5:31:09 PM(UTC)
by bill52387 1/26/2010 4:58:09 AM(UTC)
by staschu 1/16/2010 3:31:45 AM(UTC)
Whirlpool Dryer Has no Heat in Dryer (Dryer Repair)
by jsanabia 6/8/2009 2:35:54 PM(UTC)
