Here is the parts breakdown.
Replacement parts for WHIRLPOOL LER4634EQ0 | AppliancePartsPros.comHere is the wiring diagram, see attachment.
First you have to find out if the powers is OK.
The motor etc uses 120 volts while the coil requires the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
Once you know that the power is good you can unplug the unit and check the parts with meter.
If the thermal cut-off is blown then are are other things that have to be checked before you replace it.
