McCarty
#1 Posted : Monday, August 1, 2011 3:08:26 PM(UTC)
McCarty
Dryer works great except NO HEAT. The inside light is not blown (I checked the bulb in another appliance) yet does not work. Could that help in solving the heating problem. The dryer is not clogged and very clean. Please help.
#2 Posted : Wednesday, August 3, 2011 1:49:17 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE7400AYW DRYER- ELE | AppliancePartsPros.com
Sounds like you may have a power problem.
You will notice in the wiring diagram that the motor and timer run off of L1 to Neutral (120 volts).
But the heater requires the full 240 volts (L1 to L2). Also on this unit the light runs off of L2 to Neutral (120 volts)
So my guess would be that you have lost the l2 side of the line.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
McCarty
#3 Posted : Thursday, August 4, 2011 4:20:32 PM(UTC)
McCarty
Thank you soooooo much. Turning the breaker on and off slowly several times did not make a difference. I will take care of checking other recommendations later this week and let you know. Your advice is most appreciated - again thanks. McCarty
No heat in dryer (Dryer Repair)
by davehriver 11/23/2011 11:01:51 AM(UTC)
by jgg35019 11/1/2011 5:28:41 PM(UTC)
no heat in dryer (Dryer Repair)
by trillo 2/9/2011 1:46:38 PM(UTC)
by lucky915 1/11/2011 12:53:24 PM(UTC)
No Heat in Dryer (Dryer Repair)
by Don Vogler 8/4/2010 5:31:09 PM(UTC)
by bill52387 1/26/2010 4:58:09 AM(UTC)
by staschu 1/16/2010 3:31:45 AM(UTC)
Whirlpool Dryer Has no Heat in Dryer (Dryer Repair)
by jsanabia 6/8/2009 2:35:54 PM(UTC)
