After I moved the arm to turn off Ice maker to remove ice tray to fill a cooler with ice, I put tray back in moved the arm down to restart Ice maker and now no ice! There does not appear to be any ice in Ice maker so I am thinking possibly the water inlet valve. The water dispensor works fine. I was hoping to find a troubleshooting guide so I can trace the problem down does anybody know if there is any available on-line?
Well aftrer further inspection found the gear broken inside the module. Time to call around for parts.
