moon
#1 Posted : Tuesday, May 27, 2008 6:23:32 AM(UTC)
moon
I have a top loading maytag washer. It filled up with water but
now just hums. Won't wash,drain.
WasherGuy
#2 Posted : Tuesday, May 27, 2008 6:27:12 AM(UTC)
WasherGuy
What is the model # ?
moon
#3 Posted : Tuesday, May 27, 2008 6:37:19 AM(UTC)
moon
I have never been able to find the model number.I bought it about 6 years ago(new) it was mid range price. I had to replace the timer when it was
less than a year old...thats when we found out there was NO model number!
#4 Posted : Tuesday, May 27, 2008 6:28:42 PM(UTC)
Check the top of the control panel.
WasherGuy
#5 Posted : Wednesday, May 28, 2008 9:03:08 AM(UTC)
WasherGuy
Sounds like a motor or a motor start switch. However, without the Model # it is hard to tell. Maytag sometimes put the ID plate on the upper back, left hand side of the control panel, look there.
moon
#6 Posted : Wednesday, May 28, 2008 10:58:50 AM(UTC)
moon
ok I looked on the control panel again the model number is not there.
I turned it on again and it hums at the fill....i turned it to drain and it does but with a horribly loud noise.Is there a belt to replace?
moon
#7 Posted : Wednesday, May 28, 2008 11:00:34 AM(UTC)
moon
If it is a motor is it worth replacing on a machine about 6 yrs old or
is it better to buy a new machine...any thoughts?
Guest (4)
Roper Washer Just hums (Washer Repair)
by MackGoose 5/11/2014 6:29:29 PM(UTC)
Maytag Bravos washer just hums even when powered off (Washer Repair)
by guytonmomma 1/18/2014 2:16:24 AM(UTC)
ge dishwasher just hums (Dishwasher Repair)
by ncfrftr 12/14/2012 11:55:38 AM(UTC)
maytag washer just hums (Washer Repair)
by dkay 6/23/2012 1:57:42 PM(UTC)
Maytag Washer just hums (Washer Repair)
by afnashcom 11/17/2010 10:24:18 AM(UTC)
Estate Washer Just Hums (Washer Repair)
by graityrra 10/20/2010 5:14:36 PM(UTC)
my washer just hums, it won't drain or spin, agitate (Washer Repair)
by j7979a 1/14/2010 4:01:10 PM(UTC)
Whirlpool Washer Just Hums (Washer Repair)
by TrooperKal 11/30/2008 5:19:25 PM(UTC)
