I have a top loading maytag washer. It filled up with water but now just hums. Won't wash,drain.
I have never been able to find the model number.I bought it about 6 years ago(new) it was mid range price. I had to replace the timer when it was less than a year old...thats when we found out there was NO model number!
Check the top of the control panel.
Sounds like a motor or a motor start switch. However, without the Model # it is hard to tell. Maytag sometimes put the ID plate on the upper back, left hand side of the control panel, look there.
ok I looked on the control panel again the model number is not there. I turned it on again and it hums at the fill....i turned it to drain and it does but with a horribly loud noise.Is there a belt to replace?
If it is a motor is it worth replacing on a machine about 6 yrs old or is it better to buy a new machine...any thoughts?
