jiml
#1 Posted : Thursday, September 6, 2007 10:24:03 AM(UTC)
jiml
I have a whirlpool GU980SCGQ3 that the lower arm is not spinning. this started a while ago and I wound up cleaning it well which helped temp. there was a lot of soap crud at the bottom.
the upper arm spins fine. there does not seem to be anything blocking the holes on the lower arm. I dont see all that hard water/soap crud like last time. if I take off the lower arm there is some food paricles I see under a screen but I cant remove the screw (holding outlet pump )
to clean it. the lower arm does seem to not swing freely compared to a relatives that has a sim model. ther seems to be friction?
jiml
#2 Posted : Monday, September 10, 2007 7:38:11 AM(UTC)
jiml
it was the bearings and seal
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
Assemble filter and lower spray arm on dishwasher (Dishwasher Repair)
by Pat Armstrong 7/21/2014 6:23:47 AM(UTC)
Amana: Lower Spray Arm Falls Off (Dishwasher Repair)
by 400wash 2/24/2014 5:48:41 AM(UTC)
Replacing lower spray arm KitchenAid dishwasher (Dishwasher Repair)
by IggyDad 9/11/2013 2:56:37 PM(UTC)
Can't remove lower spray arm (Dishwasher Repair)
by stumpedinCA 1/18/2013 4:07:42 PM(UTC)
Lower Spray Arm (Dishwasher Repair)
by Goldie01 1/15/2013 2:49:21 PM(UTC)
How to remove lower spray arm on GE dishwasher GSD4060n10ss (Dishwasher Repair)
by fo1rd 1/14/2012 12:19:41 PM(UTC)
Take apart Whirlpool lower spray arm assembly (Dishwasher Repair)
by valv00 1/12/2012 4:36:53 PM(UTC)
Maytag Dishwasher - lower spray arm not spinning (Dishwasher Repair)
by MarkOpti 8/1/2011 6:55:17 PM(UTC)
Remove Lower Spray Arm on GE Profile DW (Dishwasher Repair)
by A1driller 3/6/2011 12:54:33 PM(UTC)
Lower spray arm (Dishwasher Repair)
by hilreal 12/8/2010 4:22:02 PM(UTC)
lower spray arm won't rotate (Dishwasher Repair)
by pap2labc 7/1/2010 11:23:37 AM(UTC)
Lower Spray Arm removel (Dishwasher Repair)
by marcusa123 2/16/2010 6:27:25 PM(UTC)
