3 Pages<123>
golfman
#11 Posted : Wednesday, May 14, 2008 2:25:01 PM(UTC)
golfman
I just replace the timer and the problem is still there. the connections also looked good. Would there be any bad connections that could cause this??
misterfixall
#12 Posted : Wednesday, May 14, 2008 3:23:06 PM(UTC)
misterfixall
but Gene ,he said he replaced timer.
#13 Posted : Wednesday, May 14, 2008 3:31:29 PM(UTC)
Groups ready for retrieval: Senior Expert, Administrators
I would not be surprised if the new timer is defective. Unfortunately I can see it more and more often.
golfman
#14 Posted : Wednesday, May 14, 2008 3:36:59 PM(UTC)
golfman
hmmmmmmmm. The brand is FSP and is the same brand I took out. I'm not sure if they'll buy that story at the part place........
#15 Posted : Thursday, May 15, 2008 2:14:32 PM(UTC)
They must!
If you'll search this forum - you can find many times when people had exchange their new parts and it solved problems.
golfman
#16 Posted : Thursday, May 15, 2008 2:35:44 PM(UTC)
golfman
Thanks, but is there any possible way it could be the lid switch acting up?
#17 Posted : Thursday, May 15, 2008 2:45:18 PM(UTC)
It will never drain if the lid switch is bad.
golfman
#18 Posted : Friday, May 16, 2008 8:44:08 AM(UTC)
golfman
It seems to spin now...............
I tried it on small load and it didn't spin.
Then I washed clothes in it on large load and it does.
I appreciate all the help. I got these for free and they are in good shape. I didn't want to spend $700 and new equipment when cleaning them up and $150 in supply lines/drain hose/timer will get me hopefully a year or two.
Thanks again guys......
stephen r
#19 Posted : Friday, May 16, 2008 1:24:01 PM(UTC)
stephen r
i bypassed the lid switch and it still didn,t work.it did agetate so i thought it was the timer .now with the new timer it doesnt do a thing .i have power what else could it be ?.could use all the help i could get. thanks
#20 Posted : Friday, May 16, 2008 2:42:26 PM(UTC)
Stephen,
Can you be more specific on the problem?
What is the complete model number of the washer?
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
3 Pages<123>
