3 Pages<123>
golfman
#11 Posted : Wednesday, May 14, 2008 2:25:01 PM(UTC)
golfman
I just replace the timer and the problem is still there. the connections also looked good. Would there be any bad connections that could cause this??
misterfixall
#12 Posted : Wednesday, May 14, 2008 3:23:06 PM(UTC)
misterfixall
but Gene ,he said he replaced timer.
#13 Posted : Wednesday, May 14, 2008 3:31:29 PM(UTC)
I would not be surprised if the new timer is defective. Unfortunately I can see it more and more often.
golfman
#14 Posted : Wednesday, May 14, 2008 3:36:59 PM(UTC)
golfman
hmmmmmmmm. The brand is FSP and is the same brand I took out. I'm not sure if they'll buy that story at the part place........
#15 Posted : Thursday, May 15, 2008 2:14:32 PM(UTC)
They must!
If you'll search this forum - you can find many times when people had exchange their new parts and it solved problems.
golfman
#16 Posted : Thursday, May 15, 2008 2:35:44 PM(UTC)
golfman
Thanks, but is there any possible way it could be the lid switch acting up?
#17 Posted : Thursday, May 15, 2008 2:45:18 PM(UTC)
It will never drain if the lid switch is bad.
golfman
#18 Posted : Friday, May 16, 2008 8:44:08 AM(UTC)
golfman
It seems to spin now...............
I tried it on small load and it didn't spin.
Then I washed clothes in it on large load and it does.
I appreciate all the help. I got these for free and they are in good shape. I didn't want to spend $700 and new equipment when cleaning them up and $150 in supply lines/drain hose/timer will get me hopefully a year or two.
Thanks again guys......
stephen r
#19 Posted : Friday, May 16, 2008 1:24:01 PM(UTC)
stephen r
i bypassed the lid switch and it still didn,t work.it did agetate so i thought it was the timer .now with the new timer it doesnt do a thing .i have power what else could it be ?.could use all the help i could get. thanks
#20 Posted : Friday, May 16, 2008 2:42:26 PM(UTC)
Stephen,
Can you be more specific on the problem?
What is the complete model number of the washer?
Guest (6)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
3 Pages<123>
