I just replace the timer and the problem is still there. the connections also looked good. Would there be any bad connections that could cause this??
but Gene ,he said he replaced timer.
I would not be surprised if the new timer is defective. Unfortunately I can see it more and more often.
hmmmmmmmm. The brand is FSP and is the same brand I took out. I'm not sure if they'll buy that story at the part place........
They must!
If you'll search this forum - you can find many times when people had exchange their new parts and it solved problems.
Thanks, but is there any possible way it could be the lid switch acting up?
It will never drain if the lid switch is bad.
It seems to spin now...............
I tried it on small load and it didn't spin.
Then I washed clothes in it on large load and it does.
I appreciate all the help. I got these for free and they are in good shape. I didn't want to spend $700 and new equipment when cleaning them up and $150 in supply lines/drain hose/timer will get me hopefully a year or two.
Thanks again guys......
i bypassed the lid switch and it still didn,t work.it did agetate so i thought it was the timer .now with the new timer it doesnt do a thing .i have power what else could it be ?.could use all the help i could get. thanks
Stephen,
Can you be more specific on the problem?
What is the complete model number of the washer?
