Woody Williams
#1 Posted : Tuesday, February 25, 2014 2:06:33 PM(UTC)
Woody Williams
Our washer will not spin at all. It will agitate and the water will drain but no spin.
After reading several threads and solutions here I purchased the Thrust Bearing Kit Part Number: AP4009132 believing that to be the answer.
Shipped one day and received the next - Thanks for the fast service.
Now my problem - The parts that came off the machine looked nothing like the parts in the package. There was no bearing on the machine, just a series of washers. One was with some sort of ridges and one was a thin compression washer. There was three or four others. I read where machines might vary so I went ahead and put the new parts on.
The only final washer that I could get anywhere close to going on there was the .032. I could not get the Reference Cam Arrow to line up between Minimum and Maximum Pulley Hub Reference marks. I tried the machine anyway and it still would not spin.
I took the .032 washer off and went with no washer. The Reference Cam Arrow then lined up between Minimum and Maximum Pulley Hub Reference marks.
Pulley had a little play in it but I tried it anyway. Machine would not spin.
The directions and video looked so simple so that is why I gave this a try.
Am I doing something wrong? Do I have the right part? Is there another problem?
I don't really want to have a repairman come out or worse yet buy a new washer.
Please help.
Thanks in advance.
Woody Williams
gesler0811
#2 Posted : Sunday, September 13, 2015 11:41:56 AM(UTC)
gesler0811
So did you ever figure this out? I am having a similar issue.
