13 Pages«<678910>»
theduke
#71 Posted : Thursday, April 22, 2010 8:34:57 AM(UTC)
theduke
Gene I have ge wbvh 6240 front loader, quick ?? I have 120 v going to invertor (tested blue red) resistance is 6 ohm on motor comections blue red blue white and white red so I can now assume it is the invertor is that correct or is there another test that I am missing
#72 Posted : Thursday, April 22, 2010 12:55:38 PM(UTC)
Sounds right.
- The inverter Part number: AP4421584
theduke
#73 Posted : Thursday, April 29, 2010 5:16:21 AM(UTC)
theduke
Gene"
Thank yoU! Washer is fixed ran two loads thru it last night.....You guys are thorough and speaking from experience always the best price on replacement parts.
Shawn
#74 Posted : Thursday, April 29, 2010 1:44:09 PM(UTC)
You are welcome Shawn. Thank you for your good words.
leolamas
#75 Posted : Friday, May 7, 2010 10:03:02 PM(UTC)
leolamas
Thanks for the great info found in this tread. I was wondering if someone could post a document here explaining how to test and replace the pump for my GE washer model WBVH6240. Under "test mode", for t02 I got errors E23, E30 and E31. Based on that, I test t05 and my pump does the humming sound but I don't see any water being pumped out (and yes, I do have some water in the washer since it was not draining - I just removed enough water to enter to "test mode" but still left some to test the pump).
I already cleaned the inside of the 3" in diameter cap found in the pump but I haven't taken the pipes off yet from it. I'll do it after I get directions of how to do this so I don't mess anything up. Hoping that it's just more debris inside the pipes conecting to the pump. Over $100 for a new pump is no fun.
Some background here: this problem started today after we got hit here by major thunderstorms with lots of lightning, the whole 9 yards. The power went down while the washer was on... and after power came back the washer stopped draining.
Thanks in advance!
Leo.
leolamas
#76 Posted : Saturday, May 8, 2010 10:45:01 AM(UTC)
leolamas
I found a great step by step guide of how to remove the pump from my washer machine at this place:
Fixing the GE WBVH6240 front-loading washing machine with Hanning pump
I followed the instructions and was able to take the pump out. And as many here already mentioned, yes, I had major debris on the pump preventing it from doing its job. All cleaned and all working fine now. Thanks for the great info posted in this tread and the link I mentioned above.
Btw, I looked everywhere inside my washer machine and there was no sign of the tech sheet that was supposed to be there. For those ones with the same problem, here is the link to a copy of it and I'm also attaching it to this post.
http://www.applianceaid.com/pdf/GEwasherFL2.pdf
Thanks again.
Leo.
File Attachment(s):
GEwasherFL2.pdf (57kb) downloaded 20 time(s).
Mr.Grimm
#77 Posted : Tuesday, May 11, 2010 9:50:37 AM(UTC)
Mr.Grimm
reset contol board from 04 to 03. Error codes are E70,E64,E61.checked buttons on control board seamed ok. even swapped out control board with another used board that board was programed to 03. Codes were E70,E31,E23. Would not tumble or spin in t10 or t11 modes. 8 monthes ago I had to replace the door boot (grey gasket) there was alot of water at the bottom of machine and control board was very moist.
#78 Posted : Tuesday, May 11, 2010 1:10:16 PM(UTC)
The error codes E61 & E64 both point to a problem with the door lock and/or its switches. According to the Tech sheet posted by Leo, you have to check the door switches and solenoid as well as the wiring and connections between the door lock and main control board.
Any error codes with the used control board are distrusted in such situation.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0WW Washer | AppliancePartsPros.com
Mr.Grimm
#79 Posted : Wednesday, May 12, 2010 9:03:45 AM(UTC)
Mr.Grimm
The error codes with the original control board were E70,E31,E23. The door lock seems to be functioning properly.The door lock codes were with the used board.
#80 Posted : Wednesday, May 12, 2010 3:25:51 PM(UTC)
Quote:
... Error codes are E70,E64,E61.checked buttons on control board seamed ok. even swapped out control board with another used board that board was programed to 03. Codes were E70,E31,E23...
This is the information you posted previously.
Guest (4)
ge front load washer won't tumble/spin (Washer Repair)
by Laeloni 3/26/2011 10:07:27 AM(UTC)
13 Pages«<678910>»
