gtohare
#1 Posted : Monday, April 26, 2010 1:58:39 PM(UTC)
gtohare
magic chef oven will not get hot. broil will get hot but when oven on cook the top element will get warm the bottom one will not. when oven is set to temp it will click or sound like it is going to cyle to get hot but will not.
#2 Posted : Monday, April 26, 2010 2:08:49 PM(UTC)
Pull out the Bake (bottom) element and check it for continuity. Make sure the wires to the element are not broken or/and burned out.
Check for 240 VAC to the element while the control calls for Bake.
Post the results.
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 59F-5TXW Walloven - S/c Ele | AppliancePartsPros.com
gtohare
#3 Posted : Monday, April 26, 2010 3:34:24 PM(UTC)
gtohare
Our magic chef oven will not get hot. Broil will get hot, but when the oven is set on a temperature the top element will get warm the bottom one will not. When the oven is set to a temperature it will click or sound like it is going to cyle to get hot, but after 35 minutes it had made it to 380 degrees.
#4 Posted : Monday, April 26, 2010 5:44:29 PM(UTC)
Have you performed the troubleshooting which I recommended in the previous post? If you did, what was the result?
gtohare
#5 Posted : Tuesday, April 27, 2010 9:00:28 AM(UTC)
gtohare
I checked continuity it is good and no burnt wires at burner checked for voltage at the wire connections with oven on bake you could hear it click like it would when it is heating up to temp. Top element gets red bottom will not get hot . I check voltage at bottom element wires no voltage.
gtohare
#6 Posted : Thursday, April 29, 2010 7:53:59 AM(UTC)
gtohare
I checked continuity it is good and no burnt wires at element. I checked voltage at bottom element with oven on bake no voltage. The top element gets hot. When you turn oven on and set a temp. the oven clicks like it always has done in the past. In the past the oven would click get hot then click and kick out at set temp. Now it clicks and then clicks like it is at set temp in just a few seconds.
#7 Posted : Thursday, April 29, 2010 12:58:32 PM(UTC)
Sounds like the problem is a bad relay board. If you need the correct part number, post the serial number of the oven.
Guest (4)
Magic Chef oven/broiler ignition problem (Oven Repair (including Ranges and Cooktops))
by steve_page@ymail.com 3/24/2015 7:07:54 AM(UTC)
Magic Chef oven controller disassembly (Oven Repair (including Ranges and Cooktops))
by amnesia 11/11/2014 4:25:47 PM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Magic Chef oven element blew and light stays on after replacing (Oven Repair (including Ranges and Cooktops))
by marbz 11/5/2013 1:30:56 PM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Magic Chef Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by chefkingoven 8/21/2012 5:48:14 PM(UTC)
RV Magic Chef oven door leaks heat (Oven Repair (including Ranges and Cooktops))
by smoky66 8/26/2011 11:31:45 AM(UTC)
Magic Chef oven bake element (Oven Repair (including Ranges and Cooktops))
by Rafat 6/29/2011 11:42:53 AM(UTC)
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 6/6/2011 12:44:20 PM(UTC)
Magic Chef Oven Problem (Oven Repair (including Ranges and Cooktops))
by Topnotch 6/2/2011 3:18:53 PM(UTC)
by Topnotch 6/2/2011 3:14:35 PM(UTC)
Magic Chef oven does not turn on - no flame (Oven Repair (including Ranges and Cooktops))
by teapa 5/20/2011 7:42:07 AM(UTC)
magic chef oven overheats (Oven Repair (including Ranges and Cooktops))
by jhelton007 12/25/2010 5:03:57 PM(UTC)
Magic Chef oven doesn't heat (Refrigerator & Freezer Repair)
by Francisco Dan 12/7/2010 12:46:57 PM(UTC)
Magic Chef oven shuts off after turning on (Oven Repair (including Ranges and Cooktops))
by svenny 12/6/2010 8:39:28 AM(UTC)
