I have a Magic Chef electric oven-range, model #: 68HN-6TVW
Oven shuts off in 5 seconds after turning on.
Do you think the culprit is the relay board, clock, sensor or a combination of the three ?
Thanks in advance for all your help.
This is happening to me too - just started happening. I have had no problems until today; I turn on the Bake option, and it shuts off after 20 seconds. Then I turned on the Broiler and that was fine Hi and Lo, and then I went back to bake and it seems to be working (for the moment). What's causing this? I baked something at 375 yesterday for 30 minutes, and it worked fine then.
