hosehead
#1 Posted : 18 years ago
hosehead
I have an Amana side by side that doesn't seem to be cold enough in the freezer. Sorry, I'm at work and don't have the model number with me...
The coils are clean and the condenser fan isn't spinning. Obviously the fan not spining will cause the freezer to run hot but the fan isn't binding, everything I read says that if it is binding, replace the motor.
I did push the blades by hand and it did begin to spin, although very slowly. Once it stopped it didn't spin again.
Is there something else I should check before I drop $40-$70 for a new fan?
jdman
#2 Posted : 18 years ago
jdman
Spend the money and replace the motor.
hosehead
#3 Posted : 18 years ago
hosehead
I did spend the money ($45 at a local appliance parts center) and it works like a champ... Thanks
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 3 years ago
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 4 years ago
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 4 years ago
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 5 years ago
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 6 years ago
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8 years ago
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 8 years ago
by projvw18t 8 years ago
by edmiller 9 years ago
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 10 years ago
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 10 years ago
by billpulsipher@gmail.com 10 years ago
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 10 years ago
by Suzalasue 10 years ago
by wnorton 10 years ago
