rjp
#1 Posted : 15 years ago
rjp
Cleaned coils 2-3 weeks ago when it first stopped cooling...very dirty..never were cleaned before. Plugged it back in after being off over night and started cooling again right away. Now 3 weeks later fridge and freezer stopped cooling again. Just unplugged it again over night and it is working again. Any ideas on where to start to look for this problem.
Thanks for your help.
rjp
#2 Posted : 15 years ago
rjp
bump...need a little help please
#3 Posted : 15 years ago
I would pull he motherboard out behind the fridg and look for bad solder joints in the back around the power relay. If ok, I would replace the board and the refigerator thermisters. Board # AP4436216, thermisters(a white, thin plastic part) AP3185407
funtime24
#4 Posted : 15 years ago
funtime24
Is the Evaporator Coil in the back of the freezer freezing up? (does it have about a 1/2 inch of frost and ice?) This may be a problem with your refrigerators Defrost Cycle and would be far less expensive to repair!
#5 Posted : 15 years ago
Pull the 3 pin power connector(gray plug) off the motherboard, notice which pins on the connector mate with the pc board line and def. pins. Stick a jumper between these pins and see if it now defrosts. If so, you have a bad motherboard. If not, you probably have a blown defrost heater.
rjp
#6 Posted : 15 years ago
rjp
There is a definite burnt solder joint on the back of the mother board...what now? replace it?"
#7 Posted : 15 years ago
Just resolder it or take it to a shop to have it done.
rjp
#8 Posted : 15 years ago
rjp
No problem...I can do that...but what could have caused it to burn and whats to stop it from doing it again. Just curious and thanks again for the help.
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 9 months ago
whirlpool fridge/freezer not cooling to proper temperature (Refrigerator & Freezer Repair)
by stephenb489 10 years ago
Fridge/Freezer not cooling. (Refrigerator & Freezer Repair)
by todd2371 11 years ago
Frigidaire fridge/freezer not cooling and fan issues (Refrigerator & Freezer Repair)
by Eric Z 11 years ago
Apartment mini-fridge/freezer not cooling (Refrigerator & Freezer Repair)
by cougartrace 12 years ago
Amana fridge/freezer not cooling (Refrigerator & Freezer Repair)
by calumnicol 13 years ago
Another Fridge/Freezer not cooling (Refrigerator & Freezer Repair)
by carjeff 13 years ago
GE side by side fridge/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by Lou7 13 years ago
Fridge/Freezer not cooling evenly (Refrigerator & Freezer Repair)
by DaneKast 13 years ago
Fridge/freezer not cooling properly (Refrigerator & Freezer Repair)
by chouseal 14 years ago
Kitchenaid Fridge/freezer not cooling (Refrigerator & Freezer Repair)
by robnuss 14 years ago
Fridge/Freezer Not Cooling, Compressor Hot (Refrigerator & Freezer Repair)
by ryanej 14 years ago
GE Fridge/Freezer Not Cooling Freezer Properly (Refrigerator & Freezer Repair)
by woody1397 14 years ago
Fridge/freezer not cooling GE model # gts18jcparww (Refrigerator & Freezer Repair)
by timdogg 14 years ago
by Peekin 14 years ago
