2 Pages<12
mrbandit
#11 Posted : Wednesday, March 3, 2010 5:18:06 AM(UTC)
mrbandit
Sorry about that. The model number is JED8230. Over this past weekend I switched the inserts and the problem stayed on the right side with the same issue. Both inserts work fine on the left side. Further testing showed that the right side only operates at the highest setting regardless of the dial selection. I have since then removed the dials from the right side.
#12 Posted : Wednesday, March 3, 2010 3:16:36 PM(UTC)
Most likely the problem is a bad one or both infinite switches on this side.
- The infinite switch Part number: AP4088404
mrbandit
#13 Posted : Friday, March 5, 2010 8:09:40 AM(UTC)
mrbandit
Thank you for your assistance and you were right, it was the switch. It was the one that controlled the big burner and not the small one that turned both on. Wierd.
I would definitely buy my appliance parts from here, but this time I didn't have to. I contacted JA and explained what happened and was transferred to the safety dept instead of a tech dept. Wierd again. They said this unit was not covered by any recalls but they agreed to have the unit fixed out of warranty. I have a feeling I'm not the only one and someone has been hurt because of the switch\wiring setup on this unit.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
2 Pages<12
