8 Pages<1234>»
PlanoRick
#11 Posted : Friday, February 20, 2009 2:55:31 PM(UTC)
PlanoRick
Is there a trick to removing the inlet protector? It seems stuck
#12 Posted : Friday, February 20, 2009 3:11:33 PM(UTC)
Thats what it says in the tech sheets: "Rotate screw-end of protector upward to remove part and expose chopper assembly".
PlanoRick
#13 Posted : Friday, February 20, 2009 3:42:09 PM(UTC)
PlanoRick
Thanks that worked. The check valve (#5 on the diagram) was missing the round part. I guess you find my problem. Do I order the part on line of would Sears have this in stock? Should I replace anything else? I did remove the dishwasher and it's sitting in my garage
Thanks again - U da man
#14 Posted : Friday, February 20, 2009 4:39:16 PM(UTC)
You are welcome.
The part number for the check valve is AP3152971and it is good in stock. You probably should have it Tuesday. I do not know where do you live and how far is a local Sears store from you.
I can not tell you if anything else has to be replaced. Probably not.
Keep us posted.
PlanoRick
#15 Posted : Friday, February 27, 2009 1:09:16 PM(UTC)
PlanoRick
Gene,
That wan't the problem. What's next?
#16 Posted : Friday, February 27, 2009 2:26:53 PM(UTC)
Check the drain pump. Remove the drain hose and make sure it's clean. Do not blow air through this hose into the dishwasher.
P.S. Have you replaced the garbage disposal recently?
PlanoRick
#17 Posted : Friday, February 27, 2009 3:20:57 PM(UTC)
PlanoRick
That was it.
#18 Posted : Friday, February 27, 2009 3:25:19 PM(UTC)
Check if you removed the plug in the garbage disposal for the dishwasher drain connection.
kcdtarheel
#19 Posted : Saturday, February 20, 2010 5:52:24 PM(UTC)
kcdtarheel
I had the garbage disposal replaced and now my dishwasher doesn't drain. I called the installer but he said they were unrelated. It seems too conincidental for that to be the case. Is there something I can check/do?
#20 Posted : Saturday, February 20, 2010 6:28:46 PM(UTC)
There is a plug for the dishwasher drain line in the garbage disposal which must be removed during the installation. Disconnect the dishwasher drain hose from the garbage disposal and check if it was removed.
Guest (15)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12/26/2012 8:55:49 AM(UTC)
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 2/28/2012 6:33:16 AM(UTC)
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 6/5/2011 6:10:04 AM(UTC)
by miketran 1/27/2011 5:50:35 PM(UTC)
by Tubhot2 1/23/2011 9:53:57 AM(UTC)
by Cappsfam 3/21/2010 7:22:43 PM(UTC)
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 12/8/2009 5:29:52 AM(UTC)
8 Pages<1234>»
