Jim Adkins
#1 Posted : Saturday, August 25, 2007 11:27:46 AM(UTC)
Jim Adkins
Washer fills OK, when full motor hums for 3/4 seconds then shuts down, slight smell. Cannot manually turn agitator. Granddaughter way overfilled with clothes. Is it the transmission, motor or both? Is it something I can reoair, I am pretty handy with tools.
#2 Posted : Sunday, August 26, 2007 1:01:17 PM(UTC)
Hi Jim
The first thing I would do is check the belts and the drain pump.
Remove two screws on the bottom of the front panel and grabbing the bottom of the front panel with both hands lift it up for about 45 degrees to release it from the top clips. Lift up the front of the washer and put something under the front leg. Remove and inspect both belts. Check how the pulley on the drain pump is moving. Replace the pump if it got stuck.
With the belts removed turn on the washer to see how the motor runs. If it makes a humming noise, does not start properly and/or producing burning smell then the motor is bad and has to be replaced.
If all of the above is not an issue then the problem is a bad transmission.
- The part number for the new drain pump AP243467
- The part number for the set of two belts AP2660760
- The part number for the new motor AP3720974
- Here are the break down diagrams for the Maytag washer Model LAT7300AAW
Good luck.
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs (Washer Repair)
by dmbailey0321 6/26/2018 11:36:55 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Whirlpool Washer Won't Agitate/Spin (Washer Repair)
by Shazaam 9/1/2016 2:47:46 PM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Washer won't agitate (Washer Repair)
by lap 8/2/2015 9:04:46 AM(UTC)
Maytag top-loading Washer won't agitate, spin or drain (Washer Repair)
by coastalhousewife 6/30/2015 5:37:07 PM(UTC)
Whirlpool washer won't agitate (Washer Repair)
by jmorgan5041 6/11/2015 12:26:59 PM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
Matag Washer won't agitate, does everything else (Washer Repair)
by Jcpstrat 3/11/2015 12:00:16 PM(UTC)
washer won't agitate, but it spins (Washer Repair)
by dee021263 11/10/2014 3:22:15 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
