estock
#1 Posted : Wednesday, March 19, 2008 7:26:42 AM(UTC)
estock
fridge and freezer not cooling at all...I hear the fan in the freezer is running.. any hints? thanks! eric
#2 Posted : Wednesday, March 19, 2008 2:00:14 PM(UTC)
Remove the back cover and check if the compressor and the fan next to it are running.
If it's not, is it warm or cold on touch?
Does it make a clicking noise once every few minutes?
Post your findings.
estock
#3 Posted : Wednesday, March 19, 2008 4:37:02 PM(UTC)
estock
Hi Gene,
Back cover is off. Fan is running, compressor is hot to touch. No clicking sounds though. I also remember smelling an electrical stink in the kitchen last week that I could not trace. Could be related?
estock
#4 Posted : Wednesday, March 19, 2008 4:49:20 PM(UTC)
estock
correction, I am hearing a relay click every couple of minutes
#5 Posted : Wednesday, March 19, 2008 5:51:09 PM(UTC)
Sounds like the compressor is bad and has to be replaced.
It has to be done by a certified tech and will cost you $600 to $800.
It's hard to recommend which way to go: fix it or buy a new one.
estock
#6 Posted : Wednesday, March 19, 2008 6:11:55 PM(UTC)
estock
UGGH!! No chance that it's the capacitor or overload relay? The comp is $280 on the sears site....really that tough to install?? thanks, eric
estock
#7 Posted : Thursday, March 20, 2008 7:01:45 AM(UTC)
estock
Okay, I understand why I can't install the comp myself...
estock
#8 Posted : Sunday, March 30, 2008 10:11:30 AM(UTC)
estock
Well, I didn't want to take any chances. I called Sears about warranty. The fridge is 6 years old, so it was not covered. They offered me a 1 year extended warranty that would cover this problem as well. For $250.00 I went for it. Guy came next day, and it turned out to be the relay. He did say that this compressor is OK, but it is poorly made. I checked the comp part on Sears, and they have changed the unit with a different model. So, that's probably next!!
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Fridge and freezer not cooling (Refrigerator & Freezer Repair)
by tommydoggett 4/6/2017 9:39:13 AM(UTC)
Fridge and freezer not cooling temp for both flashing 0 (Refrigerator & Freezer Repair)
by Biggie121 1/25/2016 11:10:41 AM(UTC)
by mousenup2 9/9/2015 5:46:56 AM(UTC)
by Victorgon 3/31/2014 8:16:38 PM(UTC)
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 3/27/2014 4:23:35 PM(UTC)
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 12/27/2013 9:07:11 AM(UTC)
Fridge and Freezer not cooling, (Refrigerator & Freezer Repair)
by jnvo 8/13/2013 4:19:21 PM(UTC)
by jnvo 8/13/2013 4:16:41 PM(UTC)
fridge and freezer not cooling sufficiently (Refrigerator & Freezer Repair)
by Frederickgee 3/12/2013 5:46:11 PM(UTC)
aaaaafridge and Freezer not cooling (Refrigerator & Freezer Repair)
by harrisdb55 10/16/2012 7:11:17 AM(UTC)
Fridge and Freezer not cooling (Refrigerator & Freezer Repair)
by chris4x4gill2 10/4/2012 6:13:38 PM(UTC)
Fridge and freezer not cooling. Fans and compressor working, possible freon leak? (Refrigerator & Freezer Repair)
by Excessumcarcer@yahoo.com 8/12/2012 1:15:41 PM(UTC)
Fridge and Freezer not Cooling properly - GE PTC22SBMARBS (Refrigerator & Freezer Repair)
by DaHadster 5/16/2012 10:19:30 AM(UTC)
by JennyM 4/24/2012 5:27:07 PM(UTC)
