My Refrigerator Is Leaking Into The Frige, It Seems That Is From The Freezer And Getting Water Build Up Under The Bottom Drawers. Anybody Has An Idea What Could Be, Also I Open The Panel In The Inside Of The Freezer And Did Not See Nothing Wrong:(
Sounds like the drain in the freezer has gotten clogged with something which caused the drain to freeze over - you'll have to take the back wall off of the freezer section and locate the drain and melt the ice around it as well as clear it out
thanks for reply, when i removed the freezer panel what i saw it was a square hole (like 2X4 inches) what i don't know is ,if that's the freezer drain? or is located somewhere else
