elbebe2525
#1 Posted : Thursday, January 21, 2010 9:37:38 AM(UTC)
elbebe2525
My Refrigerator Is Leaking Into The Frige, It Seems That Is From The Freezer And Getting Water Build Up Under The Bottom Drawers. Anybody Has An Idea What Could Be, Also I Open The Panel In The Inside Of The Freezer And Did Not See Nothing Wrong:(
Qtip
#2 Posted : Saturday, January 23, 2010 7:44:33 PM(UTC)
Qtip
Sounds like the drain in the freezer has gotten clogged with something which caused the drain to freeze over - you'll have to take the back wall off of the freezer section and locate the drain and melt the ice around it as well as clear it out
elbebe2525
#3 Posted : Monday, January 25, 2010 2:55:19 PM(UTC)
elbebe2525
thanks for reply, when i removed the freezer panel what i saw it was a square hole (like 2X4 inches) what i don't know is ,if that's the freezer drain? or is located somewhere else
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 1/13/2023 5:12:29 AM(UTC)
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 9/22/2020 4:12:05 PM(UTC)
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 8/2/2020 9:55:52 AM(UTC)
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 11/22/2019 8:15:56 AM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 4/28/2014 7:03:27 PM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 2/10/2013 11:16:13 AM(UTC)
Refrigerator leaking (Refrigerator & Freezer Repair)
by TomFrykman 1/22/2013 1:29:54 PM(UTC)
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12/31/2012 4:38:59 AM(UTC)
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 11/11/2012 11:11:53 PM(UTC)
Refrigerator leaking water (Refrigerator & Freezer Repair)
by swiss54 8/17/2012 5:19:43 PM(UTC)
Frigidaire Refrigerator leaking water (Refrigerator & Freezer Repair)
by GLORY S 5/16/2012 7:48:26 PM(UTC)
by Barbara Lim 1/16/2012 12:18:53 AM(UTC)
