SpatchDog
#1 Posted : Saturday, January 26, 2008 1:32:19 PM(UTC)
SpatchDog
The light switch on my Sub Zero 550 is broken. I ordered a new light switch, but I don't know how to install it. It appears that the old one should just pop out and the new one go right in its place, but it's not that simple. Can anyone help me?
kooler
#2 Posted : Monday, January 28, 2008 1:15:04 PM(UTC)
kooler
Many light switches require the need to actually disassemble the plastic lining or trim section in the side of the fridge/freezer compartment which the switch is located in... That way you can squeeze the 'dog ears' on the switch body that firmly hold it in place and easily remove it... Trying to pry it out from the front usually will crack the plastic lining so I don't recommend that maneuver... Especially with a Sub Zero, I hear there's some of their models that sell for over $10K... And of course disconnecting the power supply before attempting switch replacement is an absolute must...
ringoes_man
#3 Posted : Monday, March 17, 2008 11:27:43 AM(UTC)
ringoes_man
I am assuming that you got to the rear of the switches by removing the plastic cover behind the grill. It is held down by a screw on its back side. If so, then press in the tab on the right side of the switch and press the switch down firmly. The switch should pop out on the right hand side. On the left hand side the switch has a small bump, not a tab, so gently hit it with a hammer, or in my case the rear of my flash light. Also, one of the switches is normally off, the other normally on. I’ve forgotten which is which.
Good luck
SpatchDog
#4 Posted : Monday, March 17, 2008 11:34:28 AM(UTC)
SpatchDog
Thank you very much! I did one switch already, and I'm going to replace the other as soon as it arrives.
hansholland
#5 Posted : Wednesday, May 13, 2009 8:53:25 AM(UTC)
hansholland
I think I have the same problem, but I am not sure which one is the light switch (there are a few "switches" up there behind the grill)?
Can any body point out exactly where the light switch is located?
Thanks so much!
Hans.
Sub zero 690 drain clog tried everything (Refrigerator & Freezer Repair)
by Guest 10/28/2022 4:26:34 AM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
Sub Zero temperature swinging 25deg-50deg (Refrigerator & Freezer Repair)
by cdog 7/10/2020 1:11:38 PM(UTC)
Sub Zero ice/water dispenser PCB switch (Refrigerator & Freezer Repair)
by Bob814 8/19/2019 5:42:32 AM(UTC)
sub zero refridgerator sweating/leaking (Refrigerator & Freezer Repair)
by eldstrom 8/11/2013 9:04:04 AM(UTC)
Defrost Timer on Sub Zero 211RFD (Refrigerator & Freezer Repair)
by Jerryc999 4/28/2013 3:37:43 PM(UTC)
Sub Zero 650 Fridge Not Cooling (Refrigerator & Freezer Repair)
by defdes 5/30/2012 3:58:02 AM(UTC)
Sub Zero freezer problem (Refrigerator & Freezer Repair)
by do96876 5/28/2012 5:11:27 PM(UTC)
Sub Zero doorseals are hot to the touch (Refrigerator & Freezer Repair)
by IBPore 5/6/2012 12:15:10 PM(UTC)
Ice Maker Leaking - Sub Zero 561 (Refrigerator & Freezer Repair)
by TimTool 3/9/2012 8:35:39 AM(UTC)
sub zero freezer (Oven Repair (including Ranges and Cooktops))
by Shepard 2/12/2012 8:05:52 AM(UTC)
Sub Zero ice maker in fridge (Oven Repair (including Ranges and Cooktops))
by sred 4/25/2011 1:43:43 PM(UTC)
Sub Zero 650 troubleshooting (Refrigerator & Freezer Repair)
by patspidy 11/12/2010 5:49:52 AM(UTC)
sub zero freezer/frig (Refrigerator & Freezer Repair)
by phalver 3/17/2010 8:02:50 AM(UTC)
Can my Sub Zero really need ANOTHer refrigerator compressor...already??? (Refrigerator & Freezer Repair)
by amyko 3/4/2010 10:32:54 AM(UTC)
