i have a sub zero freezer 501F its cold inside hot on the outside. refrigirator stays at 60 degree it will not get cold. what can be the cause.:confused:
A model number may help though info on sub Zero is hard to find.
Usually a hot exterior is due to:
1. Dirty condenser coils under the unit. 2. Dirty/clogged vents on the kick plate or rear machine compartment cover. 3. Dirty evaporator fan blades. 4. A slow or not working condenser/compressor fan. |
THIS FORUM IS DEAD!!!!!!! |
thanks for your help its a subzero 501f
