Shepard
#1 Posted : Sunday, February 12, 2012 8:05:52 AM(UTC)
Shepard
i have a sub zero freezer 501F its cold inside hot on the outside. refrigirator stays at 60 degree it will not get cold. what can be the cause.:confused:
#2 Posted : Monday, February 13, 2012 3:01:54 AM(UTC)
A model number may help though info on sub Zero is hard to find.
Usually a hot exterior is due to:
1. Dirty condenser coils under the unit.
2. Dirty/clogged vents on the kick plate or rear machine compartment cover.
3. Dirty evaporator fan blades.
4. A slow or not working condenser/compressor fan.
Shepard
#3 Posted : Monday, February 13, 2012 9:17:22 PM(UTC)
Shepard
thanks for your help its a subzero 501f
#4 Posted : Tuesday, February 14, 2012 3:58:18 AM(UTC)
I was able to find the following manual which may be useful to you.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=363
Sub Zero freezer problem (Refrigerator & Freezer Repair)
by do96876 5/28/2012 5:11:27 PM(UTC)
sub zero freezer/frig (Refrigerator & Freezer Repair)
by phalver 3/17/2010 8:02:50 AM(UTC)
