I have a Fridgidaire Euroflar sub zero dual compressor/ evaporator. The unit ran fine when I brought it home, used. One time the freezer door did not shut properly and thawed everything. After shutting the door ,my freezer temp would not drop below 0 F whereas before -30 F would be achieved. The comp seems to be running excessively. This unit is manufactured in Sweden. Thanks, Paul
Check to see if the evaporator is frosted over with a snowy frrost; and see if the evaporator fan is running. Report what you find.
Originally Posted by: magician59 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Check to see if the evaporator is frosted over with a snowy frrost; and see if the evaporator fan is running. Report what you find. Evap.in freezer is frosted over and fan is not running,there was some ice build up bottomside of ice maker. Very Good What next Paul
Originally Posted by: phalver ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Evap.in freezer is frosted over and fan is not running,there was some ice build up bottomside of ice maker. Very Good What next Paul I discovered a loose fan wire. I connected the fan wire and energized the system along with defrosting the evaporator coil. Hopefully my evaporator is superheated properly. ( fan works). I will inform you of how much heat energy will be removed, Thank You Paul
