phalver
#1 Posted : Wednesday, March 17, 2010 8:02:50 AM(UTC)
phalver
I have a Fridgidaire Euroflar sub zero dual compressor/ evaporator. The unit ran fine when I brought it home, used. One time the freezer door did not shut properly and thawed everything. After shutting the door ,my freezer temp would not drop below 0 F whereas before -30 F would be achieved. The comp seems to be running excessively. This unit is manufactured in Sweden. Thanks, Paul
magician59
#2 Posted : Wednesday, March 17, 2010 8:14:31 AM(UTC)
magician59
Check to see if the evaporator is frosted over with a snowy frrost; and see if the evaporator fan is running. Report what you find.
phalver
#3 Posted : Wednesday, March 17, 2010 11:46:40 AM(UTC)
phalver
Evap.in freezer is frosted over and fan is not running,there was some ice build up bottomside of ice maker. Very Good What next Paul
phalver
#4 Posted : Wednesday, March 17, 2010 12:07:07 PM(UTC)
phalver
I discovered a loose fan wire. I connected the fan wire and energized the system along with defrosting the evaporator coil. Hopefully my evaporator is superheated properly. ( fan works). I will inform you of how much heat energy will be removed, Thank You Paul
Guest (4)
