The door seals on the refrigerator and the freezer of my Sub Sero side-by side are hot to the touch. Is this a problem? How can I fix?
I cannot find any info on this unit. Often a hot frame is that the condenser coils under the unit are dirty. Even a dirty condenser fan can cause this. Also check the vents at the front and back of the unit are clean. Also check that the condenser/compressor fan is running when the compressor is running. Make sure the unit has some room behind it. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for your reply. I am wondering if there is a thermostat on the door seal heater?
Not that I know of butI have no tech info on this units.
Some units do have a switch often called an Eco or PowerSaver or something like that switch. It turns a heater in the seal frame area on/off. Take a look at the units control console. Though it usually just warms the frame up to prevent condensation if the relative humidity is high.
The only ones I have seen are low wattage and do not have a thermostat. |
