fiorillo
#1 Posted : Tuesday, December 8, 2009 5:29:52 AM(UTC)
fiorillo
My Whirlpool Quiet Wash dishwasher is not draining. I cleaned the drain hose and also checked the drain check valve and it was still not draining. I then removed the connector to the motor and checked the resistance on each pin of the motor. I took readings of 12, 9 & 6 ohms so I suspect I have a bad motor. Any help on this would be appreciated.
ciroc
#2 Posted : Wednesday, December 9, 2009 7:27:34 AM(UTC)
ciroc
SAME exact problem with my GE Profile. I went through the same troubleshooting as you- ?? It seems to run fine otherwise.
fiorillo
#3 Posted : Wednesday, December 9, 2009 10:38:09 AM(UTC)
fiorillo
I took the motor out and everything in the tub, cleaned all parts thoroughly and is still not draining... has to be the motor. It's probably $150 motor and a 10 yr. old washer vs. a new one for $400. Probably go new unless the motor is under $100.
ciroc
#4 Posted : Thursday, December 10, 2009 7:43:35 AM(UTC)
ciroc
We are taking it all apart this weekend. I'll let you know how it goes!
fiorillo
#5 Posted : Thursday, December 10, 2009 7:55:32 AM(UTC)
fiorillo
The motor for my Whirpool is a complete pump and motor assembly and is $226. Time for a new dishwasher. Good luck with your trouble-shooting.
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12/26/2012 8:55:49 AM(UTC)
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 2/28/2012 6:33:16 AM(UTC)
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 6/5/2011 6:10:04 AM(UTC)
by miketran 1/27/2011 5:50:35 PM(UTC)
by Tubhot2 1/23/2011 9:53:57 AM(UTC)
by Cappsfam 3/21/2010 7:22:43 PM(UTC)
by singh_kirpal 1/15/2008 4:31:44 PM(UTC)
