my oven does not ignite ,but my stovetop burners are fine. what could be the problem?
Most likely the problem is a bad oven igniter. Replacing the igniter should solve the problem. To access the part you have to remove the oven floor and the flame spreader. - The part number for the oven igniter is AP2014008 Gene.
