reneechgo
#1 Posted : Friday, March 9, 2012 3:46:03 PM(UTC)
reneechgo
Purchased Slide-in Range and installed summer of 2002. After nine years, noticed the smell of gas when setting oven and that it didn't light immediately; occasionally, not at all. Eventually, the oven stopped lighting. Am able to light manually, but there have been times when it would not. Broiler works, stovetop burners work. An element in the rear of the oven glows when oven temp is set. Would it be the igniter, the sensor . . . ?
Simon / APP Team
#2 Posted : Friday, March 9, 2012 4:24:27 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
If you have the clamp on amp-meter, clamp it on one wire of the bake ignitor and turn the oven on. It should read approx. 3.25 amp if not then replace it.
The oven ignitor Part number: AP3126125
Post result.
